Which one is better to use on a application like a snowmobile or other power sports vehicle that can be exposed to the elements such as snow, water, or mud.
NO-OX-ID and Ox-Gard are water resistant and conduct electricity, unlike dielectric grease. I prefer either of those for electrical connections over dielectric grease.
Dielectric grease doesn't conduct. But it's displaced from the connection mating surfaces when the connector is plugged in, so it doesn't prevent a connection. Unless, perhaps, the tension on the connector is so weak that it can't push the dielectric grease out of the way. But if that's the case it was a poor connection to start with, which would likely overheat.
