Vehicle in question is 2005 Suburban Z-71 w/ 8.25" front diff & 103k miles.
I changed the rear diff fluid at around 88k miles but was bad and didnt change front diff fluid until now (at 103k miles).
Front diff had original fill.
I noticed the right axle seal had a leak. Didnt see fresh leaking fluid, but signs of grime build-up where the cv shaft slung it around.
From what I have seen on the Amsoil website, the front diff hold 3 pints (48oz).
When I drained the diff, only 40 oz drained out. So I lost 8oz over 103k miles.
Being cheap, I cleaned the right side seal area real well and didnt fix it.
I instead filled the diff first with 32oz of Castrol 75w-90 sythetic gear oil then 16oz of Lucas Synthetic Oil stabilizer. the Lucas bottle says I can mix up to 50/50 in diffs.
The 3 pints I installed didnt raise the fluid level to the fill hole, so I added 10oz of amsoil 75w-90 until the level raised to the fill hole.
I now have 58oz of fluid in the diff that spec's 48oz.
My question, will the 10oz extra be harmful to the diff?
I used the Lucas to see if it wouild stop the seal leak. I cleaned the axle and seal area so I could detect if it leaks still.
Also, where is the other end of the vent hose on the front diff, and how do I make sure it is working properly?
thanks for your input
