I got a burst of engery this morning and decided to do some winter prep work on my 08 Jeep Liberty 3.7L. I drained out the raditator and replaced the coolant, no flush just a coolant change.
I jacked the front higher than the rear and filled the radiator and over flow tank, started it and ran it with the radiator cap off, leaving some space for coolant to move and air to escape. When I was sure air stopped coming out I topped it off and put the cap on. As the engine cooled it would draw coolant from the overflow tank, I kept it topped up. About half an hour later I took the cap off the level was down about 3/4" inch so I topped it up and repeated the process. More air came out.
When I was certain the air stopped I topped it up again and ran it for about a minute and saw no bubbles, I capped it.
The heater was on high and temp was at its normal position.
Is it necessary to repeat once more or am I GTG?
My Fords I bleed thru a heater hose, but I have a Prestone T Flush unit installed I don't have one on the Jeep.
TIA
TIA
