The OP posted he did multiple d&f's, thus the use of 17 qts. And some folks use the term 'flush' for a complete ATF exchange. Besides the AT d&fs method, a trans cooler line exchange can be done using the return line. While some experienced can make it a one man job, I'd say having two people will make it go more smoothly and effortlessly. If desired, it's likely the most efficient and least expensive (less ATF) way to exchange all the ATF on Hondas. But no chemical "flushes" should be used, but I'm not aware that anyone does them anymore.
I'll add there's one line of thought that doing a complete exchange on a neglected trans can hasten the failure of an AT. So some believe doing some d&fs over a period of time 'might' be safer. I'm not aware of any science behind that, just anecdotal. Could be just that those ATs are in such bad shape the drastic fluid change could have some effect. Or, just coincidence.
But I don't believe using Dex VI in Honda spec'd Z1 is an issue.
Guess I should ask, how's it shifting?
