Dexron III ATF in 1981 Camaro?
Baltimore, Maryland U.S.A.
I was buying some ATF and I had a question that the parts guy couldn't answer.
I wanted to know if it was O.K. to use today's Dexron III ATF in a 1981 Camaro, which back in the '80's, called for Dexron II?
The parts guy told me that the car may need "special" Dexron ATF for 1980's-era Chevys, and that you had to buy it at the dealership or some speciality source.
He wasn't talking about simple "high-mileage" ATF that you can buy today, like MaxLife, for example. He was talking about some type of 1980's era-type Dexron, manufactured today to fit the specs of the early 1980's GM/Chevy cars.
Is any of this true?
Thanks in advance!
From what i've read the current Dexron III is backwards compatible with II.
It should say on the container that it is Dexron II, III etc. All ATF Dexron III I have looked at are compatible to all prior spec;s.
I put Dexron III in a 1964 Impala Power-glide trans and it worked like a charm.
You can usually find the data sheets for the name brands on the net, try Google, thats where I find info.
Ditto. I am running Maxlife Dex III in my '65 Nova Powerglide, and I have put Dex III in several TH350s (most likely the trans your Camaro has). Dex III is backwards compatible. You will have no troubles.
In 1975 when the turbo 350 transmission in my '74 Chevelle was rebuilt, the shop in L.A. that rebuilt it used type F transmission fluid. They said at that time they used it in all of the rebuilt transmissions they did. It gives a little firmer shift than Dexron. The car still has type F fluid and last time I drove the car it still shifted like new.
I've also had a mechanic recommend type F fluid in the older GM transmissions, saying it makes them shift better.
