We all know Mobil 1 already meets this new Dexos 1 GEN3 spec. They met this spec since 1979
Spider charts are not about meaningful numbers. They're a way to show you how one spec is tighter or looser than another, without revealing anything more specific. Maybe the inner circle is "like B," and the outer one is "like" A+.It's hard for me to understand these charts without any meaningful numbers. ...
relatively speaking is the most inner circle like F, then D, C, B and A? ...
These look like charts you give to high level management to leave you alone ... lol
I came across this comparison spider graph on the Lubrizol website. Unless my eyes are deceiving me, it looks like D1G3 has a lower standard for wear and sludge protection compared to D1G2. Are motor oils getting to the point that piston cleanliness, LSPI, and turbo charger cleanliness, are beginning to sacrifice wear and sludge protection?
When times get tough the tough get cookin'.My only question is at what cost and what real gain?
Yes for sure its 16 years young and only has 143xxx miles on it. Trust me it isn't going to wear out this weekend!When times get tough the tough get cookin'.
Time For Porsche A40 approval lubricant n that Corolla in your signature - or else its days are numbered!
Pure speculation in my behalf: Maybe GM is simply formulating (*cough-cough* demanding *cough-*cough*) in a bias that simply works for their engine building schema, metallurgy, fit, finish, etc?
Gooses. Ganders. Which suits one may not always suit the other...? *Shrug*
Probably not a whole lot of anything different.Nonsensical gibberish. What is GM doing different that would have them do this?
What the MIN spec is and how the oil YOU purchase rates are two different things. Most " Premium" "Full Synthetic" lubricant comfortably outperform and they tout this in ads on the bottle and in PDS.*Good points regarding wear protection and sludge control being lower on new D1 Gen 3 oils ... With my Hyundai 2.4L (non turbo DI engine I will not be extending any OCI's for sure !
Hi All, I am a technology manager at Lubrizol responsible for development of new passenger car oil additives (including dexos1 products) and was part of the group that put that performance spider chart together. To clarify, the reason we rated the relative performance of the Gen3 wear spec a bit lower than Gen2 was because GM removed an engine test (RNT) and replaced it with a bench test (MTM) and generally an engine test is a better method of evaluating performance. The spec does still utilize the Sequence IVB wear test, which is also part of API and ILSAC specifications. The sludge-handling performance comparison is a similar situation where GM removed a sludge handling engine test (M271 EVO) and replaced it by making the Sequence VH (API/ILSAC) a final formulation test with more stringent limits than those of GF-6.I came across this comparison spider graph on the Lubrizol website. Unless my eyes are deceiving me, it looks like D1G3 has a lower standard for wear and sludge protection compared to D1G2. Are motor oils getting to the point that piston cleanliness, LSPI, and turbo charger cleanliness, are beginning to sacrifice wear and sludge protection?
