Dexcool in 1990 C1500 ?
West TN
I tried searching before posting , but out of curiosity could Dexcool be used in a 1990 Chevrolet 350 ? The engine was rebuilt about 10 years ago and I understand it came filled with an green IAT coolant. I've always used regular AMAM Prestone in it since the rebuild and it's close to being due for a change. None of the cooling system components are original.
I do believe Dex-Cool is only to be used in an airtight system.
That's the primary reason for asking. I was wondering about it. Apart from color is there any major differences between Dexcool and Universal Prestone ?
Even when rebuilt with modern gaskets ?
Dexcool was reformulated to solve the issues of the past.
In the past it would cause corrosion, eat away at gaskets and gel up even in cases where different coolants were not mixed, this is not the case no more for a properly maintained cooling systems. Of course the issue of mixing still stands though.
Me personally on older GM vehicles Prestone All Vehicles is my choice. I do not like the idea of running Dexcool in a system that was not designed with Dexcool in mind and the universal coolants covers it.
I should have explained further. Prestone AMAM is chemically the same as Dexcool, except it's dyed yellow/green and has a small amount of phosphates in it. Switching to Dexcool would be a very slight step backwards with respect to corrosion protection, but really you'd be fine either way. I'm not a fan of Dexcool's color, because it makes it harder to see if rust is starting to form or if something else is going wrong like exhaust gases making their way into the coolant. Prestone and other universal Dexclones' yellow color makes it easy to see if something is amiss.
