Roger:quote:
Originally posted by Roger3116:
OK OK You have just about convinced me to use Delvac 1. What filter would you recommend? I currently use a Fleetguard #LF667 but could use a syn. filter #LF3379 at a much greater cost.( 5x ). Perhaps I should change the conventional filter every 10,000km and run the oil to 30,000km? The last question I have concerns TBN. I assume this is how to judge the life left in the oil when I do a used oil analysis, but my used oil analysis does not show it. I am using Toromont S.O.S. in Toronto Ont. This is the only one I seem to have access to in Canada. Can I use the used oil analysis without the TBN to extend the oil change. Thanks again for all your advice. Roger
Now you have me confused.
After expressing reservations about extended oil drains, I suggested you run Esso XD-3 0W-40 ($4.25 a litre at your Esso Bulk Dealer) in the coldest winter conditions, which is Cat approved.
Or you can go to your Cat dealer and purchase their own special synthetic 0W-30, though I have no idea what it's priced at.
In summer, continue to use whatever 15w40 you want. I suggested Esso XD-3 15w40, priced around $2.25 a litre at your Esso Bulk dealer.
You really have to extend the drain intervals out to make Delvac 1 5W-40 "pay" for itself, and if you're reluctant to do that, I really can't see any reason to do so.
The Esso XD-3 0W-40 is supposed to now be a full PAO synthetic, which at $4.25 a litre is about one half what Mobil wants for the Delvac 1. Esso recommends their XD-3 0W-40 in ambient temps up to +10 C / 50 F in Cat motors.
Also remember that when Mobil reformulated Delvac 1 to CI-4 specs, it's now quite a bit thicker. I have my doubts if it is good to -40, whereas Esso XD-3 0W-40 is MRV BPT rated to -45 C / -49 F.
Since Mobil now refuses to comment on what their MRV BPT value is, I have to assume they have quite a bit to hide from us. Although my used oil analysis is still good, I may no longer use Delvac 1 after the next oil change cycle.
Jerry
