delo 400 for race use?
Changing to a diffrent brand of oil filter will change the pressures as well so keep that in mind.
I also see no problem with the oil pressures you have now.
Oil pressures you should be looking at are the max and the min you are seeing on the gauge.
Do you have an oil temp gauge?
at its lowest idle pressure is 10psi after a few 1/4mile run.
its got 50psi by 3krpm and 70psi at 4krpm.
motor is doing great on this oil.
