I have a Dell Dimension 5150 running OEM XP sp3, with all updates as of a few days ago. I installed my Promise Ultra TX2 controller card in a PCI slot and attached an old HD with backups on it. Then booted up. The card & the HD were detected, saw XP on the screen, then chkdsk started up and the HD on the card was checked (??? not sure why), it found a couple things amiss, fixed them, XP booted, desktop came up, all looked well. (I'm not up to speed on Chkdsk at all but I'm curious what it was doing and if there is a log file somewhere it wrote to)
Then I went to device manager>SCSI & RAID controllers>WinXP Promise Ultra100 TX2 IDE controller>driver details> and see this:
Microsoft
7/1/2001
Ver 5.1.2600.5512
MS Win Comp Publisher
Wow, old. So I went to Promises' site, found a newer driver from May 2003 Ver 2.00.0.42, dwnld'd it, updated, XP said the driver wasn't 'signed', I installed anyway, then finished.
Rebooted. It hung at "Ultra BIOS unable to install because no drive is connected" or something like that. So I turned it off, disconnected the HD attached to the card, turned on, booted, XP loaded, I rolled back the driver, shut down, reconnected the drive, rebooted and everything worked fine.
I found another driver on Promises site ending in .34 and tried that one; no joy. Called Promise tech support, said driver signing made no difference, but had no explaination why a newer driver wouldn't work. He told me to use the old one from above.
I did some searching thinking perhaps this was a Dell-related thing, but didn't turn up anything conclusive.
Any thoughts?
BTW, the drive on the card is set to Master and connected to the middle connector on an 80-wire cable. I used it on an older machine to hold acronis backups. It doesn't have any OS on it.
Microsoft
7/1/2001
Ver 5.1.2600.5512
Any thoughts?
