JHZR2
Staff member
I have a 2006 LG dehumidifier (50pt, IIRC) in my workshop, which is segregated from the rest of the basement (which has a big Santa fe dehumidifier). I've run it with the same settings since then, so I have a lot of history with it.
This year, first time ever, it will run for long periods of time, and ultimately build up a ton of ice on the top of the case.
It never did anything like this before over the years, and nothing has changed.
Ice starts at what looks like a small solenoid before wheree the tubing connects to the forward heat exchanger. It grows in that top corner, not sure where it goes to in the end.
Fan blows well over the coils, which are spotless. The filter and all is clean too.
Here is the machine with front off and some closer up phone pictures.
So again, nothing has changed. Basement isn't cooler than any other year. Compressor does cycle, and humidity does drop slowly. But I can't imagine that ice is good.
Currently have it on timer setting so that the ice can melt. But it isn't keeping humidity to where I want it, and tools will surface rust if not lower.
Suggestions/ideas?
Thanks!
Suggestions/ideas?
Thanks!
