Decking Recommendations - Questions
Scituate MA
I am planning a deck. I am confident I can do it and I know neighbors that can help if I get stuck. I also got a Black and Decker book for more technical aspects and codes.
Going to go with the enginerred Trex or other recommendations? I do like the spindles that are eng. (don't want to paint) and maybe a wood railing?
Any advice/recommendations. Really like the look of this one.
House with deck and deck 2
I have been building decks for the past 30 yrs. Rough framer by trade. I have used Trexx many times. Downside is price and weight. If this is your first framing project I strongly recommend hiring someone to at least frame it and build your stairs. You will be spending a substantial amount in materials and it gets extremely expensive if you start making mistakes. I have always been a fan of pressure treated SPF.
If your deck gets a lot of sun, the trex gets really hot , hotter than treated wood. In the summer sun its too hot to walk on here in NC.
I love that our plastic "wood" deck does not require paint. It does still get mildew and needs pressure washing once a year. But that's a one hour project, not a one weekend project. I have a neighbor who pressure washes seemingly weekly, we don't take it that far. I have another who has to restain his green pressure treated pine every other year, I'm not sure why but I'm sure he regrets not paying more for brown treated or cedar.
I'd agree with above, it you get help for one day have it be the day you make the stairs. Also you'll need help digging the holes for the post footings, I'd rent an auger and have a friend for that. Otherwise like anything else if you have a question ask... the biggest risk is knowing just enough to have the confidence to waste a bunch of material (not that I would know personally... ha!). I have [edit: seen, not done] some some terrible projects on AVSForum where two months in someone posts their first picture and everyone is like "I hate to mention but you really have to tear that all out"...
And as much as I despise inspections if they do indeed to one (some just take your money and never come on site) that's probably worth a hundred bucks.
Oh, also, the fasteners you use, both nails and hangars must be compatible with the pressure treating your lumber has. Times Ten. And two more times. I think this isn't as much of an issue but looking at houses the last time we bought revealed this was a real problem a decade or so ago and still could be.
Trex is hot and more expensive and does not provide any structural strength.
HomeDepot has hangers for everything. You can buy the sides of the stairs precut.
You will need to go down several feet to below frostline with a sonotube or similar.
Building permit?
I've built quite a few large, multi-level decks. many with wood, cedar, and a couple (and a dock) with trex. I can only echo what others have said: its very heavy and provides no strength. but I love the maintenance free aspect of it.
