Originally Posted By: SteveSRT8
You should have a 40F degree drop between outside temperature and vent temperature.
This has always been my minimum standard. Around here it is not uncommon to get 100+ ambient, you need cold air and lots of it!
I really think my vehicles with electric fans enjoy an advantage over my engine driven models.
And my lowly Chrysler has some of the best AC ever, not just for cold but for ease of operation. Jump in and start it up, you immediately get fresh outside air for about a minute or so then it switches to recirc and really gets excited. All automatically.
Speaking personally, that is my fear with this Blazer 4.3. I had misremembered, and thought that it had electric cooling fans "that kick on at 220." This is further proof that my father did not know what he was talking about; as I now find out that it operates off of a fan clutch.
You would assume that a working fan clutch would make it cool properly, but on the "Lamborghini Aventador vs Rat Rod" episode (the Rat Rod had a 350SBC,) when idling in SoCal traffic, the 350SBC overheated, and overheated badly. Blew rap or hose before it came home, it was bad. That had a fan clutch, IIRC, but maybe the eccentric design of the Rat Rod had o air moving for cooling? Still, in traffic for a long time, I feel a fan clutch WOULD run hot/overheat, and the 4.3 is essentially a smaller SBC...
Electric fan vehicles, you could let it run all day, I'm sure.
Maybe old school fan clutch engines just don't cut it idling in traffic in heat, and that may be asking for trouble.
Unless, if it works properly, it's fine? Even when AC is on and it is 115-ish outside out?? ....
And in Death Valley and similar places (Miami?,) that means inside the car would be 80-90 degrees or so, with a 40-degree drop and AC on FULL BLAST....
