- Joined
- Nov 23, 2020
- Messages
- 242
Forgive me if this is a subject that has been covered already....
2014 CLA 250 4MATIC
Have a stack of liqui moly products and filters to do all the fluids as my 250 is just about to hit the 100k mark
Finally going with the liqui moly 5w40 in the green bottle with the dye i have been eyeballing that stuff every time I see it
Liqui moly 8100 for the dual clutch transmission I am fairly confident that is the correct fluid
I have liqui moly GL4/GL5 85W90 for the rear diff is that correct?? I seem to be getting some mix up on wether or not this or the 8100 also goes in the rear axle ?
Next question is the "transfer case" sharing fluid with the dual clutch or are they separate cases?
I downloaded the owners manual and unless I was not finding the correct section any fluid chart or info is not intended for the typical Mercedes-Benz owner to know
Lastly it seems the 2 main MB forums i have tried to join either aren't accepting new members or they think I am a spammer no luck with repeated attempts to join only to be given a rejection e mail
Any CLA250 friends or forums anyone can recommend
Thanks Mike
2014 CLA 250 4MATIC
Thanks Mike
