Kickster, perhaps I should clarify for everyone's benefit:
The compression test was done according to FSM procedure, which is as follows:
1) Start engine (I started with an overnight-cold engine in my garage both times with similar outside-ambient air temps).
2) Run (idle or rapid idle) engine until operating temp is reached and radiator fans cycle once.
3) Stop engine.
4) Remove all spark plugs and disconnect fuel injector wiring harness.
5) Test compression with throttle plate blocked wide open.
That's simplified a little for brevity, but that's the FSM procedure. I also tested each cylinder this time with the throttle plate both wide open and also shut (like at idle). The difference between open throttle and closed was under 10 psi on all cylinders and under 4 psi on 4 of them.
So, in summary, the tests I did WERE done under the same conditions and according to FSM procedures. While I understand some natural skepticism (I'm a big skeptic myself and was convinced nothing had happened until I ran this test), your level of attack here is unwarranted and unsupported by the facts in this instance.
P.S. If you'll Pay-pal me $0.01 for doing this work I'll suddenly be a professional. Not knocking you or anyone else here, but "professionals" have screwed up SO many more of my vehicles, business books, finances, and legal matters than I ever have it's no longer funny. So, my experience with "professionals" is that if they are genuinely what I would accept as professional, they will look at what was done and say: "Well, that's as repeatable as we can make it and it's how we'd have done it so it looks right to us."
