Looking to keep my 94 Land Cruiser with 436,000 mi running for more miles.
History, I either put lots of miles on it from commuting or it sits for months at a time either just driving a few miles a week or no driving at all. Been using Rotella T6 with LM Motor Oil Saver. It is used 1 qt after 1800 mi, 1 qt after 1100 mi, 1 qt after 900 mi, 1 qt after 800 mi, 1 qt 900 mi and 1 qt after 700 mi.
I drive about 500 mi a week right now and planning a trip to AK from CO this summer.
I believe that the blowby is more than the PCV can handle and the oil is getting contaminated. I am working on better evacuating of the crankcase.
I get startup smoke. Its a large cloud unless I add LM Motor Oil Saver.
Compression Results 436,000 mi
Dry - Wet
#1 135 - 145
#2 145 - 160
#3 140 - 160
$4 145 - 150
#5 150 - 170
#6 155 - 170
Per Factory Service Manual
New 171 psi or better
Min 128 psi
Max between cylinders 14 psi or less
From a test on 6/2006 292,000 Dry- Wet
#1 155 - 165
#2 155 - 165
#3 155 - 165
#4 155 - 170
#5 160 - 180
#6 165 - 180
Loss of PSI in 144,000 miles of driving from 292,000mi to 436,000 mi Dry- Wet
#1 20 - 20
#2 10 - 5
#3 15 - 5
#4 10 - 10
#5 10 - 10
#6 10 - 10
I am going to go to a conventional oil with a 3000 mi oil change interval.
My question is, should I just keep using an oil additive or would I want to try a motor cleaner or ring-free cleaner?
Dry - Wet
#1 135 - 145
#2 145 - 160
#3 140 - 160
$4 145 - 150
#5 150 - 170
#6 155 - 170
Min 128 psi
#1 155 - 165
#2 155 - 165
#3 155 - 165
#4 155 - 170
#5 160 - 180
#6 165 - 180
#1 20 - 20
#2 10 - 5
#3 15 - 5
#4 10 - 10
#5 10 - 10
#6 10 - 10
