Daylight Savings Time!
Patman
Staff member
Guelph, Ontario
In many parts of the world today is the beginning of Daylight Savings Time, so don't forget to set your clocks ahead one hour. Also, you can adjust the time on this board too, by going into your profile.
blerg, we lost daylight savings last weekend.
A week later, and our 15 month old daughter is starting to get used to it.
(Personally I'd prefer daylight svings in winter. I can handle going to work in the dark, and would much rather have a potential hour of sunlight when I get home)
Also, don't forget to change the betteries in your smoke detectors
My smoke detectors are wired into the electricity of the house (not sure how safe that is though, but it's the way the house came)
There's an echo in here...but the reminder is good...
I wish they would figure out how to make 18 hours of sunlight here on Dec 21.....
But, alas June 21 coming up.....Check your map...I live in the northern US
P,
BITOG ain't goofy....you need to stop day-dilooly-dreaming about chinese chicks!
I usually hit www.time.gov the day before the clocks change to get accurate time and set my watch, then all my clocks are spot on when I reset them. The site's linked to the atomic clocks and it runs a java application on your computer giving you the time plus the accuracy (usually better than +/-1 second). The day the time changes the site is overwhelmed and they disable the java application.
Anybody else have an accurate time fetish? Does it go with the oil and filter thing?
Sheepishly raises hand, most of my clocks are set via that method.
I even run an NTP client in the house that updates my linux boxen several times a day.
Now if I could just hook the VCR, clock radios and car clocks to the network...
TB
I'm that way too! Every clock/watch I set has to be correct right to the second!
I find that I manage time a lot better if I leave my watch off.
After a few months without a watch, I'm usually accurate to within 5 minutes.
With a watch on, I look at it, feel like I have plenty of time, then end up late.
As to setting the VCR...I could care less, there's nothing worth recording anyway.
Thats how I am too. And for the few things I do record, Tivo takes care of all the details including time.
