Patman
Staff member
In many parts of the world today is the beginning of Daylight Savings Time, so don't forget to set your clocks ahead one hour. Also, you can adjust the time on this board too, by going into your profile.
My smoke detectors are wired into the electricity of the house (not sure how safe that is though, but it's the way the house came)quote:
Originally posted by medic:
Also, don't forget to change the betteries in your smoke detectors![]()
OMG you posted it twice and still mispelled batteriesquote:
Sheepishly raises hand, most of my clocks are set via that method.quote:
Originally posted by Rick in PA:
I usually hit www.time.gov the day before the clocks change to get accurate time and set my watch, then all my clocks are spot on when I reset them. The site's linked to the atomic clocks and it runs a java application on your computer giving you the time plus the accuracy (usually better than +/-1 second). The day the time changes the site is overwhelmed and they disable the java application.
Anybody else have an accurate time fetish? Does it go with the oil and filter thing?![]()
I'm that way too! Every clock/watch I set has to be correct right to the second!quote:
Thats how I am too. And for the few things I do record, Tivo takes care of all the details including time.quote:
Originally posted by Shannow:
I find that I manage time a lot better if I leave my watch off.
After a few months without a watch, I'm usually accurate to within 5 minutes.
With a watch on, I look at it, feel like I have plenty of time, then end up late.
As to setting the VCR...I could care less, there's nothing worth recording anyway.
