I have a 2002 CR-V with and M/T that has been experiencing erratic idle issues since bought used. Simply, revs hang with clutch in at about 2,500 rpm on 2-3 shifts around 20 mph when cold. I am chasing the theory that this is the window when the purge control valve opens and there is a vacuum leak in the system. I have replace the solenoid actuated valve on the TB and replaced the downstream test valve with a straight piece of vacuum line to try to isolate the problem. That gets me to the firewall. No luck. In an effort to test the rest of the system all the way to the canister I am wondering if I can go low positive-pressure via compressor at the firewall and listen for leaks. Just wondering if this will damage anything and how much pressure to use. Thanks for any help.
