My first set of axles lasted 400,000 km without damage but I cut a replacement in 2000 km
If you don't want to read anymore the main question is, "What kind of glue do the split boots come with?" The damage must have occurred when I had the axles flopping around to change the wheel bearings. Anyway, I just had an alignment done so I want to patch up my cut boot. The cut is very close to joint so it won't be in an area that balloons during driving. I tried some Latex caulking with no luck so today I pumped two ounces of CV lube in there with a gigantic needle.
I then attached a piece of bicycle innertube with some blue RTV. Tomorrow I'll drive around to see if it falls off right away. The cut is 1/2" long while the patch is 2" long so there is lots of overlapping. I was planning on using some rubber cement but my stash was AWOL when I went looking for it.
Thanks, Steve
Thanks, Steve
