CV axle flange bolts?
California
I'm having a bear of a time attacking 6 bolts that hold a CV axle onto a diff. It's a 10mm Allen, and I've tried wailing on it with a impact wrench with no avail. Should I grad a long extension at Sears and a breaker bar and have someone sit in the car and hit the brakes while I attempt to break them loose?
I hate those bolts. When we had a Merkur in the shop, and had to pull halfshafts, we ended up going through 2-3 good Snap-on torx bits by the time we were through with it. One old tech told me to hit the bolt heads hard with a ball peen hammer a few times to "break them". Still ended up breaking torx bits on them.
It's on a Lexus LS400, so I'm betting they are right-hand threads. I can see the threads on the diff side, I'm calling the local boat yard for some Penetro 90.
The bolts would likely come out with little effort if you heat the heads nice and red with an oxy-acetylene torch then let them cool. Of course, that wouldn't be a nice thing to do to either the bearing or the bolts... so this would only be an option if all parts are being replaced.
Oh yeah! Got the axles off after a trip to the commissary(Sears and the local boat yard). Penetro 90 did help with getting the axle bolts off, along with a 10" breaker bar and a cheater pipe. :)
Only causality was a 10mm hex bit, I was able to get a new one. Sears rocks...
