Cutting steel math question
OK so if I was to buy a full 4 ft. x 8 ft. sheet of 1/8 in. thick mild steel plate, how many 2 in. x 8 in. pieces could I get out of that?
Correct me if I'm wrong:
48 x 96 = 4608 square inches.
2 x 8 = 16 square inches.
4608 divided by 16 = 288.
So am I right? 288 pieces out of a full sheet?
OK I'm assuming the metal shop would use a hydraulic shear to cut the pieces. How much waste would that be?
They have a CNC laser cutter but I think it's for odd shapes. All I'm wanting is a bunch of rectangles.
Don't know for sure, depends on how they cut the coupons. I'd say for planning purposes to "lose" one row and one column.
So, your max minus that amount.
From my perspective, no different than if I was cutting those out of a sheet of plywood.
Maybe they use some type of water jet
Water jets have a kerf of ~0.020”~0.060”.
A sheared edge will look like this.
This was my thought. From the perspective of not having all the info, this is pretty safe since the rectangle is a decent size to where the combination of all of the cuts likely won't add up to more than one width of a rectangle.
If it was an extra small part, it's very likely you'd lose a couple rows/columns.
I'd count on getting 253 pieces. That is 23 rows of 2" wide and 11 lengths of 8" long. That will allow waste.
Best to get it cut by a water jet. You're probably looking at $1k for all of this.
Shearing was mentioned, but I suppose there has to be some accounting for inaccurate sizing of the original piece and how much it might need to be deburred.
Keep us posted on how many you actually get, I suppose shearing is the only way not to have material loss cutting them.
I wonder if electron beam is possible? I know welding is with it.
E-beam welding? Wasn't that used for the titanium wing box for the F-14?
I think of e-beam from my work, where we could take the top off an IC package, point an e-beam at it, and the reflection would be sampled in order to sample the state of a particular wire. Very expensive, but often the only way to failure analysis.
