[Cut] Quaker State QS3387A (PF47 xref) 2k miles
Central PA
Pulled this off when I did an OC to check for coolant, hence the short run. Was used for about a month and some days. Nothing exciting to see here, but since I hacked it I figured I'd post anyway.
One of the end-caps popped off very easy, but I'm going to attribute that to my smooshing the can/that cap with the strap wrench I have to use (There isn't enough space to use the typical cup-style I like).
The posse:
Media:
Laid out:
Media measured out at 105sq/in.
Looks good. Does anyone know if the efficiency on those is the same as the Classics?
As always, thanks for cutting and posting!
Efficiency is a little less than the Classics. I was told Quaker State's are 94% at 20 microns where the Purolator branded ones are 97%?
Originally Posted By: LT4 Vette
Another quality filter from Purolator.
+1
Now if you have a cut open Fram Extra Guard xref to this filter, you will see much less media.
