One of my kids are in computer animation, and we recently built a PC for 3D rendering/animation (also suitable for gaming). The details of my build is here. https://pcpartpicker.com/b/vjtgXL
Our budget was $1500, and we did not exceed too much (~$1650). We still need to pay Microsoft for Windows10, that is $140 now. It's one heck of a computer with lots of compute power.
Particular things I added to the system were support brackets for the GPU (weighs 3 lbs) and for the CPU cooler (weighs 2.5 lbs), so that these components do not put all the stress to the motherboard in the upright position of the PC. We fix cars, and when it comes to computer building, we can use our mechanical skills to find a solution and fabricate needed hardware for the lack of thoughtfulness of the PC case industry.
These brackets are simple corner & L-shaped brackets. The GPU bracket is made of a leftover tie-plate, cut to size and drill elongated holes for flexibility of positioning. For the cooler bracket, it's made of 1/16in thick, 1in wide aluminium flat bar, taking advantage of the Dark Rock Pro 4 cooler access holes for fastening. After the cutting, bending, drilling, dremeling, painting, I felt a good sense of accomplishment after the project, so wanted to share with you.
