Current Mobil 1 Wear Protection ?
PNW
I recently read where Mobil 1 5W30 had a much higher wear rate (based on a standard SAE test) versus Valvoline and Pennzoil ... To be fair , these synthetic oils were not Dexos 1 Gen 2 rated , so would be curious how Mobil 1 5W30 D1 Gen 2 would stack up against the other big synthetic oil makers (I.e. Castrol , Pennzoil & Valvoline) also making D1 Gen 2 now ?
I recall that it was around the time of Hurricane Katrina, the Valvoline published results showing poor wear performance for Mobil 1 5w30. I think a little later. Castrol published something similar. It was during the API SM era.
We all wish we knew how current oils perfom relative to each other. You have to pay a lot of money to get that data. Last I looked, it was many thousands of dollars. I can't remember who that data can be purchased from. Tom NJ has stated who they are.
This discussion is 10 years in the making... Remember when people wouldn't use M1 because of high iron on used oil analysis and the sky was falling yet you have folks on here that have done tons of trouble free miles well past the junk points of most vehicles before, during and after that.
Use what you want but to call M1 a higher wearing oil when there is a mountain of evidence that contradicts that is nuts.
I've run Mobil 1 for more than 30 years in many, many vehicles, including ATV's and lawnmowers, and never had an issue. I've got all the data I need.
I wouldn't be surprised if those companies took advantage of post-Katrina Exxon Mobil and did that test on their oils that were lacking some additives or the right base oils. They wouldn't be the only ones that used Katrina to their own advantage.
I use Valvoline and I like it but their advertising hype money could have been better spent showing perhaps how much they had increased the wear protect in their oil.
As far as wear protection being lower in Mobil which I use as well I'm going to write this off as
There may have been some truth to that with the older Mobil formulations, SM for example. When Katrina knocked out their PAO production plant and Mobil was scrambling to meet demand, there seems to have been a problem with the formulation. Valvoline, then Castrol used this in their marketing. Valvoline said they had 4 times the wear protection of Mobil 1, and Castrol said they had 8 times the wear protection.
With the latest formulations of Mobil 1, I don't think there is any issue of wear protection. In fact, on Mobil 1's website, they talk about how their oils provide unsurpassed wear protection according to the Sequence IVA test.
Here is a copy of what they say, and the link to their website.
"What is the difference between Mobil 1â„¢ Extended Performance High Mileage motor oil, Mobil 1â„¢ High Mileage motor oil and other high mileage motor oils?
Wear protection starts with reducing metal-to-metal contact. According to the industry-accepted Sequence IVA engine wear test, the Mobil 1â„¢ family of motor oils offers unsurpassed wear protection. Mobil 1 Extended Performance High Mileage and Mobil 1 High Mileage oils are part of our line of advanced full synthetic motor oils using the latest in additive and base oil technologies. In addition, Mobil 1 Extended Performance High Mileage oils are the only high mileage motor oils that guarantee 15,000 miles of protection. "
https://mobiloil.com/en/faq/product-faqs?View=20&Page=2
tig hasn't posted in a week so here you go:
Originally Posted by tig1
My 40 year experience with Mobil 1 oils at 10K OCIs have never produced any sludge or varnish in various Ford engines including Escorts.
Mobil stated that M1 has met the SN Plus performance standard since 2010. Obviously it has changed for the better since the Katrina formulation.
