- Joined
- Jan 15, 2026
- Messages
- 29
Did a December replacement of a pair of Pirelli Scorpion Verde AS that I have used since 2020 for just shy of 50,000 kms. They were manufactured in 2019.
Tyre techs here said they could go for a few thousand more kms, but parking in the sun, 2000+ kms of gravel desert driving and other off-road use, and thousands of kilometres of rough tarmac surfaces meant they were suffering from dry rot with some surface cracks and tread block chipping.
Of course they were unsafe to use as they would skid if you braked when it drizzled and road surface was wet grit.
Had some uneven wear either from poor alignment or suspension wear, as some of the wear markers were reached but others still had some depth to go.
Replaced them when I saw cracks under the tread blocks under load.
Comparatively, had Kumho Crugen HP71 that I put 500 kms after the Pirellis but had to remove 6 months before and 6,500 kms before cause despite a lot of tread, they had gotten so brittle they got a clean hole puncture on the shoulder.
Question is whether I could take the word of the tyre techs on keeping the Pirellis
for a few thousand kms with no risk of blow out. After unmounting the tyres one is so out of balance it falls over on a flat surface.
Kept the tyres more out of maxing their usage on concern of pollution.
