Cruze Oil and Water Temperatures
Oddly enough H-D also used that same technology to make the automatic carb enrichener on the old Buell Blast.
Originally Posted By: MrHorspwer
GM's "on-demand" charging systems all incorporate an actual hall-effect current sensor on the negative battery cable. It is not just a simple algorithm that reduces voltage based on engine speed and load. Actual electrical demand, actual battery state of charge, calculated battery temperature, and a whole slew of other factors will affect how the alternator is controlled.
For example... Rickey: next time you're monitoring voltage of your ScanGauge, turn on the headlamps. The BCM will recognize the input and should immediatly hold the voltage at 13.9-14.5 V.
As for the thermostat, it's actually quite simple. It is a regular old wax pellet thermostat that starts to open at 221 degrees F and is fully open at 248 degrees F. That's a pretty hot thermostat and is where the "ECM controlled" comes into play. The "ECM controlled" part is just a heating grid. The ECM applies anywhere from 0 to 12 V to the grid. More voltage means a hotter grid and creates a localized hot spot that will melt the wax pellet and open the thermostat earlier. With the full 12 V on the heating grid, the thermostat will being to open at 176 degrees F.
Thanks for the spot on info Sir.
I was unaware of the charging behavior regarding the headlights. This too is correct by my observation.
I suppose there would maybe be negative comments regarding headlight brightness changing if the car used the same charging algorithm when the headlights were on.
Rickey.
This fantastic new technology is on my 05 Silverado.
