cross reference please.
Indiana
Kawasaki 16097-003 / 16097-007 to a Napa gold filter ? application is my 2015 Kawasaki Teryx 800cc 4 seater. I see no logical reason to buy "power sports" filters at $12-15 a pop when automotive filters work just fine.
please and thanks for a cross reference.
I used the link and yes it worked (thank you) however it of course directed me to the $12 power sports filters. Ive used standard car filters on atv's, mower's, motorcycle's etc forever with no ill effects. so im looking for the cross reference (standard automotive $5 filters) with the same threading.. to switch from the ubber expensive power sports filters to standard Napa gold automotive filters.
(sorry I should have been more specific)
From teryxhq forum:
oil filter is 16097-003. I have cross referenced to a few others
Fram ph6017a
Wix 51358
Napa 1358
One person uses Mobil M1-108 also.
I would check the specs out closely, but everyone agrees that the filter is about half the price of the Kawasaki branded one. I could not get the Wix cross reference to come up with these answers.
Originally Posted By: JayhawkRoy
From teryxhq forum:
Fram ph6017a
Wix 51358
Napa 1358
Thanks a lot, I appreciate the post, However the Napa 1358 is a power sports filter $11-$12 bucks each. that's close to Kawasaki's price at around $14 I believe. Ill buy the Napa and take the $2-$3 saving. Surely there is a standard Napa Filter that cross references ??
however the Fram filter is only $5 that wix filter is $10 The Napa is $11 and the Kawasaki is $14-$15 obviously all these filters are going to fall under the same spec im sure..
I think you have to do it kind of the old fashioned way. Using the dimensions and specs from Napa's 1356 filter, I found that the Purolater PL14610 is very close.
That cross cross referenced back to the NAPA 41356, 31356, 21356. The height dimension is a little taller (3.4" vs 2.78"). The gasket and other dimensions look very close.
http://www.oilfilter-crossreference.com/convert/KAWASAKI/16097-0003
AC-Delco PF2135
AMSOIL EAOM103
ARCTIC CAT 3201-044
ARCTIC CAT 3201-451
AUTOEDGE AL6017A
Baldwin B1400
Baldwin B7285
CARQUEST 85358
CARQUEST 85365
ChampLab PH2876
ChampLab PH7015
ChampLab PH7028
DENSO 115010-5390
Donaldson P502067
EMGO 10-26920
EMGO 10-82230
EMGO 10-82251
Fleetguard LF3925
Fram PH6017A
HASTINGS B7285
HASTINGS LF113
HIFLO HF198
HIFLO HF204
HIFLO HF303
Honda 15400-P0H-305
Honda 15400-P0H-305PE
Honda 15400-PFB-004
Honda 15400-PFB-007
Honda 15400-PFB-014
Honda 15400-PJ7-015
Honda 15400-PLM-A01PE
Honda 15400-PM3-405
Honda 15400-POH-305
Honda 15400-POH-305PE
Honda 15400-ZJI-004
Honda 15400-ZW4-003
Honda 15410-MCJ-000
Honda 15410-MCJ-003
Honda 15410-MCJ-505
Honda 15410-MFJ-D01
Honda 15410-MM5-013
Honda 15410-MM9-003
Honda 15410-MM9-013
Honda 15410-MM9-405
Honda 15410-MT7-003
K & N KN-198
K & N KN-204
K & N KN-303
K & N KN-303C
KAWASAKI 16097-0002
KAWASAKI 16097-0003
KAWASAKI 16097-0004
KAWASAKI 16097-1058
KAWASAKI 16097-1061
KAWASAKI 16097-1063
KAWASAKI 16097-1064
KAWASAKI 16097-1066
KAWASAKI 16097-1067
KAWASAKI 16097-1068
KAWASAKI 16097-1070
KAWASAKI 16097-1072
Kubota 15853-32430
LUBER-FINER PH2876
LUBER-FINER PH7015
LUBER-FINER PH7028
MELROE 6671057
MERCRUISER 35-822626
MERCRUISER 35-822626Q04
MERCRUISER 35-822626Q1
MERCRUISER Q03
MERCURY 35-8222626Q03
MERCURY G590000-G760299
MERCURY G760300-1B226999
MERCURY P086824-P325499
NAPA 1358
NAPA 1365
NAPA PS1358
Nissan 3R0076150M
Parts Master 61358
POLARIS 2520799
POLARIS 2540086
POLARIS 3084963
POLARIS 3089996
Purolator ML16817
Purolator ML16819
ROBIN 2576730111
SIERRA 18-7902
SIERRA 18-7909
SIERRA 18-7910
SIERRA 18-7911
SIERRA 18-7911-1
SIERRA 18-7913
SILVERLINE 21358
STP PH7028
Suzuki 16097-1072
TOHATSU (Marine) 3R0076150M
TRIUMPH MOTORCYCLE T1210200
TRIUMPH MOTORCYCLE T1210444
WARNER PH7015
WESTERBEKE 30220
Wix 51358
Wix 51365
YAMAHA 3FV-13440-00
YAMAHA 3FV-13440-00-00
YAMAHA 3FV-13440-10-00
YAMAHA 5DM-13440-00
YAMAHA 5GH-13440-00
YAMAHA 5GH-13440-00-00
YAMAHA 5GH-13440-10-00
YAMAHA 5GH-13440-20-00
YAMAHA 5GH-13440-50-00
YANMAR 124450-35100
That NAPA 1365 might be a good match, difference is that it's .2" shorter. Personally, if you have the headroom, I'd be inclined to go with the slightly longer x1356 filters. Either way, you'll be saving over the power sports model!
Originally Posted By: bubbatime
The Fram PH6017A is $5.17 on Amazon as an add on item. Add a 5 quart jug of Mobil 1 10W30 or Pennzoil Platinum 10W30 and your almost at free shipping if you don't have Amazon Prime. Buy two filters and a 5 quart jug and you got your next two oil changes for under $35.
http://www.amazon.com/Fram-PH6017A-Black...words=Fram+6017
5 quart jugs of good priced oil
http://www.amazon.com/Mobil-112796-10W-3...ngine+oil+mobil
http://www.amazon.com/Pennzoil-550038321...0w30+engine+oil
Don't forget to stack on the $12 online rebate for the Mobil oil too!
awesome response ! I stopped and chatted up my friend at Thompsons motorsports here in Terre Haute IN, he set me up with a Kawasaki genuine filter for $9 Lucas front diff gear oil (I don't like lucas oils) But for a 50 hour till the next interval ill use it, and Kawasaki rear diff fluid. He discounted everthing. Now that I have a filter in hand im going to go to Napa and compare just to be sure. Clearly the Fram is the cheapest, are we having good luck with Frams now ? OCOD ???
Thnaks so much for the the list !!
