Criticize my article on another forum
Florida, USA
I moderate NICOclub, which is a Nissan-centric forum. I specifically moderate the Pathfinder / QX4 section. I recently wrote a rather long "general information & FAQ" type thread, and would appreciate any feedback, criticism, suggestions, or corrections.
Here is the thread in question: http://forums.nicoclub.com/pathfinder-qx4-general-information-and-q-a-t549378.html
The first post contains a lot of information that may not necessarily be Pathfinder specific, so skim through that Q&A section at least. The last section is a general oil & filter FAQ - this is the specific section that absolutely would benefit from some fact checking or suggestions for additional content.
No criticisms, well written and nicely done. I have a question.
On the lower control arms.. Are the bushings just rubber with a metal sleeve in the middle?
The first half of the Q&A of; "What is an engine oil analysis?" can be worded better, IMO.
You wrote; "An analysis of a used or virgin oil sample to determine..."
I saw you change it to something like this; An analysis of a used or virgin oil sample is used to determine...
What do you think?
Thanks for the feedback everyone.
I'm not sure, I've never replaced the bushings yet.
What do you think?
I've corrected that. Thanks
Otherwise, looks good. Nicely worded and will definitely be a help to the average Joe understand this stuff a little better.
