So I have a FL-400S I found with a “creased” can - you can see some creasing on the can at the baseplate crimp. OK to use, or should I cut it open for science?
That’s what I meant to say. If I do use this filter, it’ll be on something I can monitor for deformation easily(two Toyotas or a Kohler Command 12).I personally don't see anything wrong in the pictures.
If you say "creasing", it is probably manufacturing defect when the metal was extruded to create the can shape.
Tops of the feet I don't mind, it's when they start showing the bottom that gets me. My work involves printing photographers images and you wouldn't believe the amount of Senior images that show the bottom of their feet, disgusting.Looks ok to me.. Why do people have to show their dirty feet in their pics?
These seniors can't bend their legs to see the bottom of their feet, so they take pictures to get the view. As to trimming the toenails, well they get a quote from the local bodyshop for extensive die grinder remedy.Tops of the feet I don't mind, it's when they start showing the bottom that gets me. My work involves printing photographers images and you wouldn't believe the amount of Senior images that show the bottom of their feet, disgusting.
Let me guess, on your first day, you never came back from your first coffee break..Lubener say: "Why do people have to show their dirty feet in their pics?"
Did I ever tell you how I lost that job in the shoe store?
Foot fetish........Lubener say: "Why do people have to show their dirty feet in their pics?"
Yep - that’s what I’m referring to.
It doesn't look any worse than a formed edge on the flutes on the dome end of a filter. Looks like it actually sticks above the can surface - true? If so, it wasn't dented inward by an external impact.Yep - that’s what I’m referring to.
