For my neighborhood HOA, we have a newer (probably like 5 years old) Craftsman gas pressure washer that won't go into high pressure mode. Any ideas? Engine runs fine and it's hardly ever had any use. I haven't played with it much at all.
Agree, pump, though they are easy to rebuild if you can get parts for it. I have several pressure washers, one being a 11hp with dual belts. The rebuild kit for that is $400! But the pump is large and heavy, to pick it up takes both hands.
When pressure washer is running but trigger is not pulled, the unloader unloads and water recirculates and heats up. After 5 minutes it melts nylon in the valve as it gets very hot.
Originally Posted By: lexus114
Originally Posted By: bubbatime
Junk it and have the HOA buy a proper pressure washer. Honda GX200 engine/Cat pump.
You can get those vertically mounted pumps for about $90 to $100 on ebay/Amazon if you really want to fix it.
yep, and it will only last a very short time again.....
All the vertical pumps I have ever seen are rated for 50 hours of use. Vertical pumps suck. They shouldn't be bought in the first place, but people do, even though they can get a comparable horizontal pump for similar money.
