I have observed using CPU ID and HWiNFO that the CPU speed on my Compaq laptop never changes. It's a constant ~1700 MHz. The CPUs in my other machines tend to throttle themselves down at lower loads. In playing with HWiNFO this afternoon, I see that it reports the CPU speed on this laptop as "locked":
Code:
CPU LFM (Minimum): 800.0 MHz = 6 x 133.3 MHz @ 1.2625 V
CPU HFM (Maximum): 1733.3 MHz = 13 x 133.3 MHz @ 1.2625 V [Locked]
CPU Current: 1728.9 MHz = 13 x 133.0 MHz @ 1.2625 V
It looks like the CPU, a...
Code:
CPU Brand Name: Intel(R) Celeron(R) M CPU 430 @ 1.73GHz
CPU Vendor: GenuineIntel
CPU Stepping: C0
CPU Code Name: Yonah-V
CPU S-Spec: SL92F, SL92B
CPU Thermal Design Power (TDP): 27 W
CPU Type: Production Unit
CPU Platform: mPGA478/mBGA479 (Micro-FCPGA/FCBGA)
Microcode Update Revision: 39
...has the ability to throttle itself down to 800 MHz. However, mine never throttles, and it appears that it's because it's "locked" at full speed. User-selectable options in the BIOS of this machine are few and far between. Are there any software/OS routes I have to throttle this CPU down when not under load? It seems like a waste of battery and heat to run the CPU at full speed with no load.
Code:
Code:
CPU Stepping: C0
