Couple questions about a '94 Corolla auto tranny
OH
Do any of you know if this car has a drain plug in the tranny pan, and how much tranny fluid drains out when drained so I know how much fluid I need to buy?
My 97 has a drain plug and being that your 94 is basically the same car I'm sure it does as well. If you drain the fluid when the car is hot you will need 2.7 quarts. If you do it when its cold you should get 3.7 quarts. The trans drain plug is on the drivers side of car and the oil drain plug is on the passenger side.
