Hi All
I did the 2nd change of ATF in my 05 Toyota Prado and this time round I have a humm - it's a "whooo" sound coming from the transmission. I did a flush and replaced 8 liters of ATF, drove round the block and it was all good. The sound started after about 15 minutes into a long drive. I can feel a vibration that's proportional to the noise and the noise is proportional to revs. The operation of the transmission is not affected at all, it shifts fine in all gears.
I double checked the level the next day and it was fine (yes I did the Toyota method 46 to 56 degrees). I plumbed a clear tube into the cooler system and the fluid has a nice red colour and is clear, no bubbles that indicates fizzing. The pressure was good based on the stiffness of the pipe. I read on a forum about a guy that had issues after an ATF flush and he then added oil and it fixed the issue.
1st time round the car might have had the original Toyota factory WS in it when I changed it to Penrite. This time round (on 260 000km) I decided to use the same brand filter (Ryco) but use Total LV MV ATF (Total energies Oil) and now I have this issue. I always work very cautiously when doing these type of jobs and kept everything clean. Both Penrite and Total has the Toyota WS spec noted. Both fluid changes were done as normal maintenance.
I suspect the noise is coming from the oil pump and not the TC. The noise is there all the time, if it was the TC the sound would change as gears are selected and when lockup occurs. (please correct me on the TC assumption)
I suspect Total ATF has sufficient differences in viscosity to possibly cause fluid noise or cavitation - what do you think?
The Total ATF is thicker (higher Viscosity) that the Penrite and Penrite is a bit thicker than Toyota WS. Toyota WS has the best viscosity index but for this issue the VI isn't relevant.
The other option that could cause this is if something got into the transmission. I checked that the old seal came out with the filter and the new one is correctly fitted.
Please see screenshots of all 3 oils.
Let me know what you think could be causing this?
