Hello all this is the Costco Roseville location in California. It’s supposedly different from the normal Bio-Diesel I see at chevrons that are B-20 locally… any thoughts on the costco fuel? I do know the top tier diesel should be better quality.
Maybe not?. It seems that renewable diesel and petroleum diesel are very similar end products of differing base stock and processing methods. I need a chemist to straighten this out.This product seems different, they claim it is NOT biodiesel, but I would assume that the characteristics are similar.
Yeah I did a google search and this renewable diesel lasts longer unlike biodieselNot sure, but I do wish Costco carried diesel around here.
Not sure I’d run b20-b100 consistently, but I’d like to at least blend it for cleaning and lubricity. I think the big question is how tbh is product differed from biodiesel in terms of solvency and lubricity.
its not biodiesel its Renewable. boy thats a confusing mouthful since bio is also in biomass.In my experience-run through it fast, bio goes bad. It’s also possible to clog filters, it’ll break loose anything in the tank. Seems like a slight MPG hit, too.
That explains why my already under powered idi runs even worse on it.Negatives:
- Less torque and fuel economy (5-7% less)
- High cetane # can cause performance loss in older diesels without dynamic timing
You may be able to find an RD/D2 blend at a different fuel station. Only one station has D2/R2 blend that I know about near me and it’s not the cheapest fuel, but it’s worth it to me. I can tell by the color and smell what is being dispersed.That explains why my already under powered idi runs even worse on it.
So far every station I go to only has r99. I messed with the injection timing in the past. I have the special tools including a timing meter.You may be able to find an RD/D2 blend at a different fuel station. Only one station has D2/R2 blend that I know about near me and it’s not the cheapest fuel, but it’s worth it to me. I can tell by the color and smell what is being dispersed.
If you can adjust the injection timing at the pump sprocket of your IDI it may improve the performance with RD.
They all have the r99 sticker here.I found the diesel blend at a station by trying different stations in my area. It is labeled as Diesel #2, but that in itself doesn’t mean anything. There were other stations I tried that were selling fuel labeled as D2 but dispensing RD. If you pump some fuel in a glass container you can tell what fuel it is. Try new station, sample, rinse & repeat.
So far every one within 10 miles or so.If that’s true, there’s no hope. If there are stations you haven’t tried check those.
So avoid the costco Renewable Diesel then and stick with the B15/20 from chevron/shellThis Renewable Diesel has been available since 2016 in CA, but not as prolific. Things changed significantly in 2024. Now, RD or blends is the only available fuel in urban locations however I’ve found pure diesel #2 in some rural fuel stations. California petro diesel #2 is excellent and superior to diesel in the other 49 states.
I’ve tested RD since the beginning, and the benefits are mostly “green fools gold”. It is a scam and highly subsidized to make it economical.
Benefits:
Negatives:
- Lower NOx and soot emissions
- No Hydrocarbons or aromatics
- Pure parafinnic fuel
Most of the emissions reductions are offset by needing more fuel to do the same amount of work. Emissions reduction claims are arbitrary as some engines create higher emissions using RD.
- Very dry with low lubricity. Lubricity must be added by blenders or by using additives by consumers.
- Causes leaks in older fuel systems with rubber components.
- High cetane # can cause performance loss in older diesels without dynamic timing.
- Heavily subsidized by CA.gov
- Emissions reductions are based on engine type and tuning. Some engines produce higher emissions on RD. See the Gladstone report funded by CARB for tests results.
