Here is some data that I downloaded from my Corvette's ECU when I did some track days at the Daytona International Speedway road course. I reviewed about 2 hours of data and found the fastest lap, which I have broken into 3 segments.
This is the infield:
[img:left]
[/img]
[img:left]
[/img]
The data of interest to BITOG enthusiasts is the oil pressure, which barely gets above 40 psi at any time, and drops to about 20 psi in long left-hand turns. No worries; the engine has been running this way since 1995. During this lapping session the oil temperature was running at ~315 F. I run Redline 5w30 with an Mobil 1 filter. The oil system is plumbed with a 2 quart Accusump. The oil system does have an air-to-oil cooler, but apparently it needs a better one. Running on shorter tracks, the hottest the oil had gotten previously was 277 F. Daytona has long periods of WOT while running on the oval.
[img:left]
[/img] [img:left]
[/img]The data of interest to BITOG enthusiasts is the oil pressure, which barely gets above 40 psi at any time, and drops to about 20 psi in long left-hand turns. No worries; the engine has been running this way since 1995. During this lapping session the oil temperature was running at ~315 F. I run Redline 5w30 with an Mobil 1 filter. The oil system is plumbed with a 2 quart Accusump. The oil system does have an air-to-oil cooler, but apparently it needs a better one. Running on shorter tracks, the hottest the oil had gotten previously was 277 F. Daytona has long periods of WOT while running on the oval.
