Patman
Staff member
Actually, the LS1 seems to like an oil that is near the changeover point between a 30wt and 40wt, so if you run a thick 30wt oil you'll get good results. It just doesn't seem to like the thinner 5w30 oils as well (the ones closer to 10cst at 100c that is)quote:
Originally posted by vazzen:
From what I have read here the LS1 engine seems to "like" a thicker oil than 5w30.
So a 5w30 or 0w30 can still work great, just try and use one that has a viscosity at or above 11.5cst at 100c. Amsoil, Redline or Castrol SLX would all work well here.
[ February 03, 2004, 10:36 AM: Message edited by: Patman ]
