Corrosion
Toronto
Is it safe to use?
Mahle OC 330, Austrian made.
Thanks
Any rust down the center tube? I wouldn't run it ... filters are cheap.
If there is corrosion outside what's the inside like. Maybe worse. Maybe flaking.
Filters are not expensive. Don't use it. You could be feeding your engine with corrosive particles that are not good for lubrication.
Fine. Use it.
Funny how they have just the tiniest crimps holding the o-ring on.
