Correct way to disconnect battery?
Originally Posted By: Pop_Rivit
Originally Posted By: HosteenJorje
Here is the answer. Put a wrench on the positive connection of a charged battery and let it touch a ground.I guarantee you will never ever do that again.
I've done that before on my Ford Ns without a single problem. In fact, when I remove the battery from one of them the positive cable is the first cable that I remove and I frequently touch the wrench to the hood without a single spark.
Want to guess why?
No need to guess. They were positive grounded.
Take negative off first is what I've always understood, this thread has clarified that you can't get a "zap" doing negative first.
But... What if your wrench / spanner (etc) touches the vehicle whilst undoing the positive on a typical negative-ground car. Won't that create a circuit?
Originally Posted By: supton
Originally Posted By: Jetronic
It takes 50 volts to break through your skin and give your body trouble.
However your tongue can feel 9 volts as it's more conductive. Give a 9V battery a lick and report back.
I can and have felt tingling from 24V....
Not surprised. Moisture content of skin and/or how much sweat (or other salts/metals) would impact how conductive you are.
I'm a good conductor
Once one battery terminal is removed, the circuit is broken. No current can flow.
"Circuit" is Greek for "circle". Current flows in circles. If a continuous circle cannot be drawn, then current cannot flow. The battery cares not which terminal is removed first, as it opens the circle and breaks the circuit/circle.
You could make the rule "disconnect the terminal tied to chassis ground first" and that would cover both types of ground systems.
The current is not the only danger.
Leaking sulfuric acid being trapped in a closed area can produce an unpleasant surprise when someone sparks a positive battery cable.
Sulfuric acid is not flammable. The danger is batteries generate hydrogen gas when charging, which is highly flammable.
Ouch!
That makes sense.
