And they are all expensive.Which one, there's like a hundred of them.
Seems like Krytox would be overkill for just a
Stinky pb blaster as a cleaner.. on something you dont typically use petroleum products on..I would clean the seals well, using some PB blaster on a rag, and see if the issue is resolved.
I have had luck with PB revitalizing rubber. Especially rubber that sits in the sun, like on RV windows and slides. Yes is smells, which is why I suggested the product on a rag. Of course, a small amount.Stinky pb blaster as a cleaner.. on something you dont typically use petroleum products on..
rubbing alcohol or hot water on a rag.
If I ever use up the can of 3in1 RV rubber and seal conditioner I have I'll try this one out.
I wouldn't use petroleum based lubes on rubber. Might look nice at first glance, but I think it's akin to putting bug spray on plastic/composite headlights because they look awesome for a day or two.I have had luck with PB revitalizing rubber. Especially rubber that sits in the sun, like on RV windows and slides. Yes is smells, which is why I suggested the product on a rag. Of course, a small amount.
You should try it sometime on some rubber, you will see the effect.
205 I think, this is from the TSBWhich one, there's like a hundred of them.
It is 205, I have a tube in front of me. And yes, it is expensive.
https://www.krytox.com/ja/-/media/f...tems.pdf?rev=cc9a9d973fef4060bf2569eb61f0b44aWhich one, there's like a hundred of them.
Sunroofs were not see-through and matched the body i.e. first gen Mazda Rx-7, although my first car a 1982 Honda Accord Hatchback had a manual rear hinged "sunroof." From my memory "Moonroofs" i.e. like I first remember Honda/Acura using the term were all glass.Considering that what we call a sunroof today, is really what was originally called a moonroof, then I suspect it will be ok.
I don't know if any auto manufacturer makes what was originally called a sunroof. I can't recall the last time I have seen one.
Thanks for the link. Brought a couple of the syringes home after a recent dental surgery and repurposed for brake lube purposes (squeaky drums from lack of lube at shoe contact points by dealer, don't want to disassemble).I just use a shop towel wrapped around a narrow trim tool to clean out all the old grease. A few passes, and I can get all the visible grease off the tracks, and it even feels very clean to the touch. I've never found it necessary to use a degreaser.
For applying the new lubricant, I like to use a dental irrigation syringe with a curved tip. The syringe allows me to apply just the right amount of grease, and the curved tip helps me get the lube on the sides of the tracks. I keep these syringes on hand for a lot of projects, including applying grease to brake calipers. Using an acid brush is just messy, for me at least. I guess it is my OCD.
https://www.amazon.com/Disposable-I...ge+with+curved+tip&qid=1714606605&sr=8-6&th=1
And hard to find - you’ll need to get it from Grainger/Zoro or McMaster-Carr. If you got a dive shop nearby, something similar is used to to lube o-rings and for internal packing called Christo-Lube or Tribolube.And they are all expensive.
Seems like Krytox would be overkill for just asunroofmoonroof.![]()
Personally, I’d use Mercedes gleitpaste. Expensive but it works great for that application.
I thought that was a dog?On all rubber seals I use Honda shih tzu silicone grease....08789-9013 silicone grease...Never ever use a petroleum product on rubber seals..
