Corolla 4A transmission torque converter HELP!!
New Zealand
Hi everyone,
I am trying to put the torque converter onto our transmission for this engine but it does not want to seal, I've tried everything and looked at all the advice and forums online. The converter itself slides onto the first spline but does not want to move any further and is wobbly, I've tried rotating it while adding pressure, I've tried jiggling it, putting it horizontally and vertically, the thing just does not want to seal. Been at this for 6 hours now and its not fun
Help would be appreciated by someone who has dealt with this similar problem, thanks
Its the same converter, the original block blew a big end so we bought a new block and transferred everything including the trans. All we did was remove the TC and now it just does not want to go back on
Why remove the converter? To install a new converter seal?
I find that grabbing the pilot nub with your fingers and wiggling it a little while simultaneously spinning does the trick.
We removed the trans with the converter still on the block, thinking back that was a mistake and we should of detached the trans with the converter still on, as now we've tried everything to get it back on for the past 6 hours
If it's like the older Corollas, We used to pull out the center spline shaft and engage it in the torque converter then slide the shaft and the converter back in place together lifting slightly on the converter while turning. Once in a while we would lay the transmission on it's back and lower the converter in place. That way worked well too. Just put it in a pan first as it will leak a lot.
You may have broke or tweaked something when you removed the transmission that way. Look for damage.
