Cooler Line Flush; Schaeffer's in 09' Ranger
Arizona
Well the truck has 24,300 miles on it now, and I've been wanting to get the FF out of there. The trans is the 5r44e.
I decided not to go with the Motorcraft Mercon V for two reasons; 1. The trans seemed to shift "firm" on the 2-3 shift and 2. I just believe the Schaeffer's is a better ATF.
So, I did the cooler flush method. I actually pumped out 3qts before dropping the pan(no mess!). The capacity is 9.9qts, so I used 10qts for the job.
I'm impressed so far, the trans has "smoother" shifts. Also, 2-3 shift is much improved, none of the slight harshness anymore. I was a little apprehensive to use non-OE fluid, but I've really liked the Schaeffer's before.
Very happy with the flush and the fluid. Can't believe I haven't used the cooler line method before, just do it once and your done!
Originally Posted By: DieselTech
Way to go Mike. Glad it all worked as planned!!
Thanks, I've now done all of the FF fluids, minus the brake fluid and coolant(not needed I think).
I used Schaeffer's ATF in the PS and Trans and Schaeffer's 75w90 in the differential.
Oh BTW, any harm in the dipstick level 1/4" above full? I don't know how it happened, I measured the old and new fluid.
Id try to get that out. Remember it will expand as it gets hot, too.
Yes, Schaeffers is an excellent fluid. The fact that it was a full synthetic (PAO?) with a Mercon V license is what sold me. Oh, and I can get it anytime from the distributor down the street. Almost as soon as I put it in after I bought my car it eliminated a slight shudder on wide open 1-2. Of course my car now shifts hard enough to screech the belt at wide open, though that was intentional.
It does smell terrible though.
You put in a nice premium ATF.
But who is to say a fresh fill of MerconV would not have had great results?
Fresh fluid in anything often helps.
Yeah, its hard to say that any Mercon V wouldnt have done the same thing. But he has 24k and I had 25k when I changed it the first time and we noticed immediate improvements.
~25k and it showed issues does not exactly impress me.
mechtech2, my reasoning is similar to Colt's. I wasn't impressed how the trans was shifting(mostly that 2-3 shift) after only 24K on the fluid. We'll have to see how this fill does after some miles, then I can report back.
Colt, I forgot to mention, the slight overfill was after checking the fluid on a 30 mile drive.
I would still drain a bit out. Remember anywhere in the cross hatch is good to go.
It will be interesting to hear the long term report. I modified the valve body so I wouldnt be able to compare FF to Schaeffer with miles.
Glad to hear you're shifting better.
I think Schaeffer's 204sat All-Trans is a highly underated fluid.
Yes, plus it's cheaper than any premium ATF I've found.
It also works great in our Corolla and my old Mark VIII when I had it.
