Originally Posted By: fdcg27
Do you have a real coolant temp gauge?
Most of the later ones are not.
A real temp gauge will show variations all of the time as driving conditions vary.
If you do, you'll find coolant temperature varies a great deal depending upon conditions.
Climbing a hill, for example, requires more power than running on level ground, using more fuel, and producing more waste heat, some of which is resolved into the coolant, so you see a commensurate increase in coolant temperature on the gauge.
If you have a real coolant temp gauge, you may simply be seeing the real increase in coolant temperature, and nothing is amiss.
Ha, good call. You beat me to it.
Start with a stat change, verify that the radiator is cool (so to speak) and and re-try the pass. If it still gets warm, see above.
