I have a 96 s10 4.3 vortec. I knew I had a leak in the radiator. Replaced radiator, all hoses, recovery tank, water outlet, and thermostat. I still have a leak somewhere else tho.
As of now, I just have water running thru it. I would like to pressure test the coolant system. But, how do I do that if there are open ended hoses on the coolant tank?
I am also gong to check the pressure thru the plugs this weekend. Hopefully, at worst it is just intake.
Any help/thoughts/advice?
thanks
JJ
thanks
JJ
