Indefinate. I have used open 10 year old coolant without any issues.Does coolant have a shelf life (sealed container)? Or even an opened container with the cap back on...
Coolant will not degrade, but the additives like water pump lubrication will, but when will degradation take place I have no clue.Does coolant have a shelf life (sealed container)? Or even an opened container with the cap back on...
Sealed container? Indefinitely.Does coolant have a shelf life (sealed container)? Or even an opened container with the cap back on...
Surprised to see relatively new Prestone Platinum premium 15 yr life coolant turned clear. After doing a flush and refill of cooling system I had about a pint left over in a 1 liter clear plastic bottle on passenger seat exposed to the sunlight. In about 10 days to 2 weeks the antifreeze turned completely clear so it looked like water, will test it to see if the freeze protection is still as rated. Must be normal then that the color fades when exposed to sunlight.Leaving them in direct sunlight does something though...
Idiot neighbor left 3 unopened bottles outside the barn door for a full northeast year, in the sunlight.
When I used them finally the coolant was clear and cloudy (concentrate zerex g05).
He didn't care, therefore I didn't.
2 years later, functions fine.
Because the 'search function' on BITOG sucks. I use 'Google' instead.Wonder why those didn't show up when I searched! Thank you kaschachn!
Yes its good, you can also test it for the level of the freeze protection with coolant/antifreeze tester, the small glass tube with balls in and a rubber suction bulb at top allows small amt of fluid and number of balls sinking or floating tells freeze level protection. If its not diluted 50/50 with water you may need to to dilute it before testing although for filling the reservoir your manual may tell you to put it in without dilution.Is this O.K. to use ? Have little over 1+1/2 year old O.E.M. KIA Pink 50/50 coolant and plan to top off the reservoir to 1/2 . It's nearing the LOW mark .
