- Joined
- Dec 28, 2011
- Messages
- 5,627
95 2.2 Camry 103k. I replaced the thermostat and radiator at 101k. Radiator rusted after 18 years. I replaced upper/lower hoses at 70k (17yr). Prior to the radiator and thermostat replacement the temp gauge would read normal cold to operating temp then drop to cold and go back to normal. Still does it months later. Sooo I would think it more a temp sensor that a gauge issue?? What do you think?
If temp sensor ok to run it this way or better to change it out?
