My dad says he isn't thrilled about me cutting hoses. So I did some searching about the T flush and found this:
"If you want, you can use an extra piece of the same size hose, and install the T without cutting the original hoses, just disconnect the original hose where convenient, connect that end to the T, and connect the other end of the Tee with the extra piece of hose. Then when done, the T can be removed and the original hose reinstalled without the worry of leaving the T there. I tried leaving the T installed once, and it leaked because it got crushed and deformed by me overtightening the clamps."
So I will do that. I just don't know what line to connect it to.
Since I can't flush distilled water through this like I was planning to, once the water is coming out clear with this, how do I get the tap water out? Is opening the radiator drain and block plugs the most effective way?
And out of curiosity, how does this method work without removing the thermostat?
