Coolant For Orden Fusion 2.5 2011
Hi, I read here a lot of post about this but still confuse. My Fusion use from stock the Motorcraft Dark Green. I read that Motorcraft Dark Green and Orange were discontinued and The replacement is the Motorcraft Yellow.
If I don't wrong I rea that the G05 is the one aproved for Ford like the replacement.
But checking, Ford example, The Zerex G05 is HOAT and The Motorcraft Yellow POAT. Not The same kind.
Am I wrong?
i am replace the Radiator for a new one and looking for The right Coolant.
Thank in avance for The help.
i think you're confusing 2 coolants...
IIRC the G05 was what my '09 sable took, which was Motorcraft Gold.
which was replaced by the Dark Green, which was replaced by Orange ( which is DEXCOOL in all but name), which was replaced by the Current Yellow.
This is the most recent version of the chart I could Find (updated August of 20204) https://www.fcsdchemicalsandlubricants.com/quickref/coolantsEN.pdf
and this:
Backward Compatibility/Use of Motorcraft® Yellow Antifreeze/Coolant with/in place of Motorcraft® Orange Antifreeze/Coolant and Motorcraft® Specialty Green Engine Coolant with Bittering Agent
If your Fusion came with the dark green, it’s a PHOAT Asian coolant. Use Zerex Asian or the like.
Hi, yeah I read this about the Asían Coolant.
I mean, With The Ford notice, about the Dark Green and Orange discontinued and replaced by Motorcraft Yellow.
The Motorcraft Dark Green Will be replaced by the Yellow Motorcraft, right? But Yellow Motorcraft is HOAT right?
And The similar in this Motorcraft Yellow, in Zerex Will be?
Thanks For your help.
and this:
Hi, thanks For your help. Yeah. I check those charts before and the notice of Ford.
Motorcraft Dark Green and Orange are discontinued and both replaced by the Yellow. I am missing something?
and this:
Motorcraft Yellow replace both Specialty Green and Orange, right?
