K koi Joined Apr 4, 2006 Messages 10 Location Oahu May 30, 2008 #1 The manual says to use only Volvo coolant that is quite pricey. Does anyone know what I can buy off the shelf that is compatible?
V Volvohead Joined May 25, 2005 Messages 3,612 May 30, 2008 #2 Just my opinion, but I'd stick with the Volvo Type C. Pricey is a relative term. Type C is cheap next to an OEM radiator or short block. Otherwise, if you must, I guess G-05 should work.
bdcardinal Joined Jun 3, 2005 Messages 17,955 Location Santa Barbara, CA May 31, 2008 #3 what model volvo? the coolant mine is green, although that does not mean much.
V Volvohead Joined May 25, 2005 Messages 3,612 May 31, 2008 #4 Originally Posted By: bdcardinal what model volvo? Not sure that should matter. IIRC, all models from MY05 use Type C as the factory fill.
A Audi Junkie Joined Nov 3, 2002 Messages 11,247 Location PA May 31, 2008 #5 I thought it was Ford G-05?
Carmudgeon Joined Apr 26, 2005 Messages 1,496 Location Under the hood Jun 1, 2008 #6 In the past, it was a green version of G48. Don't know if that's changed. Older Saabs (pre-2001) and BMW also use G48, in blue/purple. Valvoline/Zerex says G05 is an acceptable substitute for all three.
