2000 Toyota Celica GT
bought it at 129k
I have always done coolant flushes with about 10 D & R with distilled water then using 50% full strength coolant and topping off with distilled water, as needed.
I'm wondering if a coolant flush chemical is a good idea, being that my OEM coolant temperature sensor failed (it was black instead of the bronze/gold original color), I used an after market sensor to no avail, found a used one from the junkyard in good working condition and used it on my car. My assumption would be that it was the original coolant at 129k/15 years old(was red in color), and this caused the OEM coolant temperature sensor to corrode?
go the 10 D & R distilled water route?
or do a chemical coolant flush like the peak radiator super cleaner and flush, following the directions on the bottle, drive 3-6 hours at operating temperature and then follow this by 9 D & R with distilled water?
bought it at 129k
